I have a 1986 Johnson outboard, which I have had for 10 years without a problem. This spring the motor was running great, until i put 5 gallons of last years fuel in it. I know..big mistake!! Now the motor bogs down when in gear. When I have it out of the water the motor will rev up fine when in gear, but once it is in the water and I put the motor in gear and punch it, the motor will bog down. I took the cover off when it was in the water, put it in gear, and pushed the throttle near the carb, and it bogs down.
I took the fuel filter off and it is fine, I need some help as this is cutting into my fishing time!!!
