1986 Johnson 8 Hp Owner Manual
kclancy
Hey Gang,
I am having trouble finding an owner's manual. I found one for a 4 Hp motor. Do you think that it pretty much the same as the 8 Hp? It is for a Johnson, but I have a Sail Master by Johnson. Is it also the same motor?
Thanks!
Kevin
Vic.S
No the 4 hp and 8 hp models are not very similar at all
You should be able to obtain the correct owners manual, service manual too if you plan on doing any maintenance yourself, from Ken Cook
Here you are
https://www.outboardbooks.com/manual/J8SRLCD/
