1986 Johnson 70hp tilt trim stuck
Suicide6
Hey guys, first post here. I have been stalking the board for awhile and usually get the answer to what I am looking for but this time I had to write my own post.
First time boat owner and purchased boat/motor in the winter and never had a prob with tilt/trim but could see a small leak in the piston. Just went other the other day and when I activate the tilt/trim button on controls I can hear the motor but it will neither lift nor let down. Both rams are stuck in place as well. I have read where I need to open the "release" screw and it will at least go down; that didn't work. I have ordered a tilt/trim O ring kit to fix that issue but to do so do I need to remove the whole motor or can i remove the three bolts on each side along with the pin at top of piston and drop the whole assembly to fix?
Also, my buddy thinks that maybe the motor is missing teeth and it needs to be replaced too since it has been trying to engage and the piston/rams are not moving.
Thank you for your time.
Joe Reeves
The appearance of the unit gives the appearance that the unit is low on fluid due to leakage.
Back out the manual release valve two turns and two turns only... Do Not exceed two turns or you will more than likely damage the sealing O Ring of the valve.
The trim rams do not withdraw in any further than what you see here when in manual mode. If your engine happened to be in a higher tilt angle, backing out the manual release valve would allow it to drop to where you see it here.
Raise the engine, lock it into the tilt position, do your repairs, fill the reservoir when done with repairs. It will be most likely be needed to refill the reservoir a few times in the full tilt position.
Be sure to replace the reservoir fill screw after filling before lowering the engine or that'll cause the fluid to flow back out.
Suicide6
Thank you Joe. I hope to have an update for you Monday night.
