Suicide6
Thread starter- Joined
- Aug 5, 2017
- 2
Hey guys, first post here. I have been stalking the board for awhile and usually get the answer to what I am looking for but this time I had to write my own post.
First time boat owner and purchased boat/motor in the winter and never had a prob with tilt/trim but could see a small leak in the piston. Just went other the other day and when I activate the tilt/trim button on controls I can hear the motor but it will neither lift nor let down. Both rams are stuck in place as well. I have read where I need to open the "release" screw and it will at least go down; that didn't work. I have ordered a tilt/trim O ring kit to fix that issue but to do so do I need to remove the whole motor or can i remove the three bolts on each side along with the pin at top of piston and drop the whole assembly to fix?
Also, my buddy thinks that maybe the motor is missing teeth and it needs to be replaced too since it has been trying to engage and the piston/rams are not moving.
Thank you for your time.
