1986 Johnson 40hp VRO fuel pump
nmantas
My cousin has a 1986 Johnson VRO 40hp J40ELCDE that we are trying to diagnose. What we have is a fuel problem. The boat runs out of gas 4-6 minutes after starting.<br /><br />Pump the primer ball until hard and start it up and it runs fine until all the gas is used up and the engine stalls. You can sustain the engine if one of us constantly pumps the ball while the other drives(helped us get off the water last time we were out). I discovered yesterday that it will run indefinitely when the gas tank is positioned above the motor.<br /><br />We have eliminated the gas tank, gas line, fuel filter as possible problems. My gut says its the $200+ fuel pump. Is there an easy way to test the fuel pump, a book we have has you fabricating a vacuum gage to hook up to the fuel-line but I don't want to mess with all that. Any suggestions or ideas? Does anyone know the OMC part number for this fuel pump?
ob
Re: 1986 Johnson 40hp VRO fuel pump
Nick,Don't have the P/N for your VRO pump but you can test by first insuring that the pulse hose is connected and not leaking from the crankcase to the pump air motor fitting.To test pump you can simply remove the pump discharge hose from carb inlet manifold and route into clear container while someone cranks engine over.Should discharge fuel freely unles pump is wore out or there is a restriction in the pumps fuel supply.
