jasper60103
- Sep 18, 2008
- 2,055
Re: 1986 Johnson 30 Power
I would focus on getting those compression numbers closer. I would check the torque on those head bolts first. A common problem is some folks don't re-torque them after they run the motor. Check the torque and repeat the compression test. You may get lucky.
Worst case, a new head gasket is about $25 at the dealer, and it's not hard to replace. I replaced one on my '88 30hp. Just make sure your head is flat to start with. Do the figure 8 with 150 grit sand paper on a sheet of glass per the manual. Torque it to spec following the proper sequence. Run the motor and allow it to cool and re-torque it again.
Stuck a piece of wire (stripped bread tie) through the high speed jet. It seems clear. After checking fuel pump operation lots of fuel ran out of high speed jet. A carb kit was installed last year to include new fuel lines all the way around. Carb was clean as a whistle. Head gasket was also blown last year but replaced (as far as I know based on what the tech told me). I'm happy to replace it again if it makes sense. Should I focus on the head gasket since the carb was redone and high speed jet was clear?
