1986 johnson 15 hp
bcflyguy
I just broke down my motor to see it i needed to replace the motor mounts or just the bushings, luckily its just the bushings that need relacing. I hav ethe seloc manual for the motor but i cant find diagrams or part numbers relating to the parts i need, im wondering if there is an inner and outer bushing and ill need to replace a couple gaskets, specifically the one that the motor was mounted onto the leg on. can anyone help with part numbers or a diagram of the area?
bcflyguy
ok i think i found the gasket but now im wondering about the bushing from inside the mout can i get it seperately or is buying new mounts my only option?
thumbnut
I made bushings out of polyurethane sway bar bushings..and they are a pretty blue!
Newyota
What bushings are you referring to?Are you referring to the rubber seals in picture?
Honorary Supreme Mariner
The factory mounts are somewhat spendy.--Some folks have used budget automotive parts to make copies of the mounts.-----Works well.------He is not referring to the rubber seal at all.----I pick up parts motors for next to nothing just to get parts like those mounts !
bcflyguy
Thumbnut which make and model vehichle did you use to fit in their
