My motor will not charge the battery? wondering if the motor was an alternator that maybe no good
I imported_kmart Recruit Joined Jul 3, 2006 Messages 1 Jul 3, 2006 #1 My motor will not charge the battery? wondering if the motor was an alternator that maybe no good
Barnacle_Bill Admiral Joined Feb 8, 2004 Messages 6,469 Jul 3, 2006 #2 Re: 1986 johnson 140hp charging problem Check your rectifier. If you ever hooked the batttery up backwards, even for a split second, its toast. Also check all connections to be sure they are clean and tight.
