1986 johnson 120 hp still not working
gerabor
1986 johnson 120 hp will run for 10 - 20 minutes and then sputter, decrease rpm, catch again, rebuild rpm. Will run for a minute or two and sputter again. About 1 in 3 sputters the engine will sputter to a stop. When I wait a few minutes, press the primer bulb several times, it will start and run again, run for a few minutes only to repeat the problem. I am not a mechanic and so I have had to take it in for repairs. I have done this four times. Secon last time a mechanic took the and tested it on a lake near his home. He would replace a part and run it. Never found the problem. The last shop said there is nothing wrong with the motor when they tested it on theri dynomometer.
It appears to be a fuel problem but I have been told the fuel pump pressure is fine. I have run the motor on auxilery fuel tank and the problem persisted. I am at my wits end. I have been to this site before with this problem. Perhaps there is a new forum member who has had a similar experience?
gm280
gerabor, I can't help but think it is a fuel delivery issue. Meaning carb or fuel injection needs cleaned which ever you have. And regardless what is said about the fuel pump, it really sounds suspect as well. The actual fact the you stated that you press the primer bulb a few times makes that assumption even more obvious. You stated that you tried an axillary tank and had the exact same problem. So that rules out the tank and primer bulb system to the fuel pump. But it certainly doesn't rule out the fuel pump. If this is the same fuel pump on the engine since new, buy a new one and see what happens. The fact that the engine runs strong on the dynamometer states that when there is fuel supplied properly your engine runs great. So look at the carb(s) and fuel pump... JMHO!
gerabor
Thanks JMHO. I will contact repair shop and get a price on a new fuel pump. I was told it is a combination fuel and oil pump that works off the crankshaft. I have the repair manual and will do some reading to determine if if have the skills to do the job myself.
gerabor
JMHO. Sorry I took so long to get back to you. Put in new VRO. Phew - expensive. Engine sputter once in a 30 minute run but kept on going. Removed air baffle and sprayed carb cleaner in the four carbs. Next 30 min run worked. Fall is here and boat is put away for winter. Motor has new spark plugs and mechanic verified they were correct ones and properly gapped. But it still runs rough and idles at 1000rpm. Will try adjusting next spring. This will be new to me. I will trust the manual I purchased with the motor. Thanks
