1986 johnson 110hp flywheel torque spec
Bee Reel
Hey everyone! It's been a while and I'm still at it. Finally got my 110 johnson up and running! Problem ended up being a broken woodrift key on the flywheel was sheared off due to improper flywheel tightening. Anyone know what the proper spec is to tighten down the flywheel? It's a 1986 Johnson 110hp model j110tlcd. Thanks!
SparkieBoat
make sure that the mating surface of the flywheel and the crank shaft does not have ANY grease or oil. it should be very clean. I just tighten mine down real tight..LOL I know that some people are torgue spec specific, but other than head bolts I usually know about how hard to torque a bolt/nut. just by feel, no problems yet. I usually get those nuts as tight as I can with a 1/2 ratchet with out busting my gut.
