75sportster
Thread starter- Joined
- Sep 10, 2013
- 4
hello everybody first time on here. I have a problem maybe a bad problem. I had real low compresion on the middle cylinder, decided it was the head gasket and it was but also found a small peice of the block missing on outside of piston sleeve. I cant tell if the gasket will be okay with this chip missing or if the motor is junk. It loks like the gasket will sit on the sleeve. and also where is the best place to get a gasket for this old motor? I am sure they are available somewhere. and should I have the head resurfaced just in case it is warped? I would apreciate any help I can get thanks Mike
