unjustentropy
Thread starter- Joined
- Dec 29, 2018
- 3
Hello all!
I recently purchased a very much so project 1990 bayliner capri (1800?) with a 1986 force 86 attached to it.
The motor has the lower unit pulled off and the two gears at the rear of the prop shaft are stripped and need to be replaced. Aside from those two gears it also needs the whole prop shaft assembly and prop.
Does anyone know where to acquire these parts or know if other engines share these same parts?
Thanks!
Thanks!
