1986 force 50 hp on a 86 bayliner
reagan
yes, thank you for allowing me this oppurtunity to gleen some insight from the pros. my 50 hp force is an 86 that ive had since 2009. the engine hours said 10 then and now stand at 120. she cranks and idles ok but has no power. this occured , out of the blue . ive tried new plugs, to no avail . i posess a the origional service manual, and parts catalogue but am hesitant to touch much. semi retired, handicapped and unemployed have forced me to look for solutions outside a normal trip to a marina. can yall espouse?
mauiboy
Re: 1986 force 50 hp on a 86 bayliner
1st thing is to check the compression then spark then fule. bad comp will not give you power and no spark to one cly will also do this
jerryjerry05
More info?? Does it rev up or no power mean no speed?
Tell us what it's doing in better detail.
Fill out the profile.You might be close to someone who can help.
Could be low comp or no spark.Is it a point setup?
