1986 Force 50 HP- NO SPARK ON ONE CYLINDER?! NEED HELP!
Status
Not open for further replies.
Lukelona
Finally trued starting my force engine for first time, wont start.
I'm not getting spark on one cylinder.
I switched the coil with a known good one, still no spark on one cyl.
the "bad" coil has a brown wire, and a blue wire,
the "good" one has a white, and a blue
If I switch the wires between the two, my "bad" coil fires, but the "good" one doesnt...
The brown wire runs up under the flywheel, not sure where its connected under there.
What does this usually mean?
please, any help is very much needed thanks
Lukelona
Re: 1986 Force 50 HP- NO SPARK ON ONE CYLINDER?! NEED HELP!
bump...
im tryin to resolve this while my brother in law is in town, We wanna take it out while hes here
So I need ANY suggestions/advise!
thanks again
Lukelona
So im leaning towards bad points/condenser...however the tune up kit is not available anywhere..
Sierra # 18-5161 & # 18-5241
what do I do now?
come on guys, I need the pros ideas here...60 views and no input?
IM LOST! lol
Nordin
As you say if you swap wires to the coil the issue moves, the problem is under the flywheel.
Take the flywheel off, clean the points and cap to 015. Normaly this will solve the problem.
Check for insulted wires that can be grounded.
You have a old school battery ign.system (without distributer), similar to an old car.
The system contents 2 points, 2 capacitors and 2 ign.coils.
Maybe the capacitor can be shorted, but that is not common.
Lukelona
what do you mean by capacitor?
The condenser?
I belive I have a stator also...It... woukd still be points and condenser setup right?
jerryjerry05
Yes you have a stator.That's what charges the battery as you run.
The capacitor is the condenser.
Take the flywheel off and clean the contacts.They need to be REALLY clean and shiny.
Sand them or file.Then check for continuity.
Get a manual.
For parts.
Try Franz marine.
Or Valley sales in Prudenville,Mi.
Both on the net
One or the other should have what you need.
Lukelona
thanks jerry...
im gonna pull f/w today.n get it to look at points n stuff.
ill post what I find later today.
Paulg443
This thread is old but hopefully you guys are still active.
I have the same engine and I cannot find the part number or the CDI box on my engine.
Engine starts on first crank and runs but only on cylinder 2. I have ordered new coils and a rectifier.
Nordin
Please start your own new thread.
This one is 7 years old.
BTW we need to know what kind of ignition system your engine has.
They use 2 or 3 type of systems in those years.
You are talking about CDI box BUT the one who started this thread had battery ignition system.....no CDI box.
GA_Boater
Please read our rules - All of them.
Status
