1986 Evinrude 90HP Bendix will not engage flywheel
largeboreiv
The bendix will pop up and spin quickly but will not engage the flywheel. I mean it will reach the correct level for the gears to engage but incorrect contact is made and the bendix teeth either will not mate properly or the bendix will spin freely AGAINST the flywheel teeth. I replaced starter last year (new bendix came on it) and it ran fine until suddenly it didn't after a few long start attempts. It seems the material of the new bendix is softer than the material on old bendix (on old starter). Could the teeth of the new bendix be ground down enough to cause this or is it more liklely the flywheel itself has worn down? I can't tell just by looking at it, but I am 99% sure the flywheel gear teeth are ok. Has this happened to anyone else?
What do you mean by --" long start attempts " in this case.---------These starters are easily damaged by long cranking.-------You might want to take it apart for inspection.------And find out / correct the hard starting issues.
oldboat1
Is the flywheel spinning when the bendix engages and spins? The flywheel may be spinning freely on the shaft. If you had starting or running issues, it may be that the flywheel position had shifted, affecting timing -- and resultant excessive cranking may have done in the starter.
[ed. Was the flywheel pulled at some point? Torque issue could be at the root of problem.]
largeboreiv
The starter is good...no damange due to excessive start attempts. The flywheel does not spin because the bendix usually just rises and spins AGAINST the flywheel teeth with no engagement/mating of the cogs/teeth between bendix and flywheel. Starter was never shimmed for correct spacing so thats out. Teeth on both bendix and flywheel APPEAR normal. Flywheel has never been pulled. One day it started fine, the next day it didn't.
F_R
It probably could be something to do with the teeth. However, as a general rule that kind of trouble happens because the starter is not beginning to spin suddenly enough. It is inertia that makes the bendix rise. The starter suddenly spins and the bendix gear lags behind, causing it to screw it's way up the shaft. Most common cause is either a bad battery (discharged or a dead cell), or poor battery cable connections. Check out those simple things before jumping to conclusions and looking for something more exotic.
rothfm
Ensign
Probably battery, if you have checked connections...I keep several batteries on my bench for testing powerheads/starters, and its amazing alot of times they just loose their power even though fully charged and reading 12.8...But just loose their punch after a crank or two.
Try a very new, fresh battery. Bet you see a difference.
oldboat1
afraid I'm just not understanding the situation: "spins AGAINST the flywheel teeth" (OP's emphasis). If the bendix gear is not properly engaging the flywheel (gear is not snapping up into position), it's almost certainly battery or connections as described. There's only one place for the gear to go if it's operating right and the starter is positioned correctly.
I kind of lean toward an installation issue (starter was not securely bolted in place, and has jarred loose) -- gears don't line up.
rothfm
Ensign
You should be able to use your fingers and turn the starter shaft, and in turn work up the bendix head..do this by hand and you should be able to wiggle it a bit and engage it into the flywheel teeth. If you cannot, agreed some sort of alignment issue. If you can, then it seems to be power related.
largeboreiv
I agree it is an alignment issue...but why would it suddenly do that? The starter is securely bolted in place and flywheel has never been removed (at least to my knowledge). They don't appear to be but perhaps the bendix teeth are ground down enough to not engage the flywheel teeth? Batteries are solid...full charge. Bendix pops up immediately but there is a tiny space between where the teeth should engage each other. I guess I need to buy a new bendix and compare the two to know whether or not its ground down. Frustrated. Thanks for all the help though...I appreciate it immensely!
dingbat
When was the last time you removed the gear and greased the shaft? Pretty common problem in SW motors.
A shot of PB blaster followed up with a film of marine grease usually remedies the issue for another year or two
oldboat1
Good suggestions. I think I would also try removing and reinstalling the starter just for grins, if you haven't done that since the problem arose. You might also check the assembly of the starter to the bracket. Anything is possible -- starter may not be fully secured in the bracket (long vertical bolts worked a little bit loose). Any small fraction of movement down at the base of the starter could mean the the gear at the top won't properly engage the flywheel. It's a stretch, but easily checked out.
don't know if it helps, but an old Chris Craft I ran had starter alignment issues -- required shimming, which I learned was also not remarkable with some older Chevy engines. I don't think I've heard of that with an outboard starter, but I suppose shimming could be a fix.
rothfm
Ensign
Maybe internal wear, and that shaft is skewed a bit.
Please post your results, so we can learn too!
Or the wrong starter. Yes -- an incorrect starter may work for awhile until the teeth are damaged and no longer mesh. Also, a battery that has a fresh charge may still have a bad cell and therefore not deliver the power needed to kick the Bendix fully into position. Have the battery load tested.
