1986 Evinrude 40 Hp E40ELCDE Carb Problems?
dkosiewicz
I have a 1986 VRO Evinrude 40 HP E40ELCDE motor and am having trouble with it running. I replaced my 3 wire VRO fuel pump last year with a new 4 wire because the 3 wire pump was discontinued. I cleaned the carbs as well and changed out all my gas lines. The trouble is now my motor wont stay running. It will start and then dies out right away. I disconnected the gas lines to the carbs and cam see that gas is being fed to the carbs from the fuel pump so I believe the my trouble is with the carbs? I cleaned them and made sure the injectors were clear. I think that the floats are not set at the right? Does anyone know what that distance this should be? Or any other advise for me to try?
Thanks in advance, David :grumpy:
oldboat1
What issues were you attempting to fix? Additionally, did you do these changes sequentially? For example, you might have tried the replacement pump and found different issues -- or no correction of the initial problem -- then moved to carb work to try and correct.
On the carbs, setting the floats level is typical, or raising the outer edge a slight bit higher. Are the floats in right side up, and nozzle gaskets in place?
dkosiewicz
HI oldboat1,
My old VRO Fuel Pump was leaking gas from a couple torn diaphragms and I had to replace it because of that issue. So I thought while I have the Fuel Pump off I might as well pull the carbs and clean them. I had gotten lazy 2 years ago and didn't put Stable in it nor run the gas out of it for winter. :- ( Ok how do I tell if I put in the floats upside down? And which gaskets are you speaking of? I had it at a Marina but they wouldn't work on the carbs and gave up on it. Not worth the $ for them. They thought it was a carburetor problem as well. I worked on it the best part of 1 day and replaced all my gas lines as well and the clamps in case of a air leak. And got it to fire up and run for several seconds.
oldboat1
http://www.iboats.com/Carburetor/dm/cart_id.589174387--session_id.353579678--view_id.1549729
can eyeball the float for the correct orientation. If it looks like the type pictured, the flat side would be facing the top of the carb -- likewise the little adjustment tab. During assembly of course, the top of the carb is flipped over so up is down.... If you have a needle with the black tip, you need the little clip that attaches over the float arm (needle can stick in the seat).
The nozzle gasket is #7 in the parts blow up. For motors that have it, fuel feed won't work properly if it's omitted in reassembly.
Technique? I disassemble top and bottom, although leave jets in place (don't like to risk damaging them). Then soak in lacquer thinner or the solvent of your choice (some use Pine Sol). Finish by blowing out all openings with carb cleaner.
dkosiewicz
Thanks oldboat1,
I checked out both carbs this am and the floats are in correctly and the #7 gasket is installed properly also. It does have the needle with the black tip and clip and both are on. I made the float level with the carb body when is it upside down.
LOL Stumalump,
I would have but I bought a new VRO Pump last year for $450.
I am at a loss now I have no idea what can be going on with it?
dkosiewicz
Still waiting to see if anyone has the info on the space in the picture below?
oldboat1
not sure about the primer lever, but think running position is flipped around parallel to the solenoid.
Your carb pic shows the float drop which may be referenced in your manual -- might be something like 5/8"(?). I don't even bother with it on mine, and just set the floats level with the edge of the inverted housing. Some tilt the outer end up just slightly, which would increase the drop.
flyingscott
Agree flip the primer lever the other way and set the floats to level like oldboat said. Did you follow the instructions VERY carefully for the installation of the VRO pump. The 4 wire VRO pump is a VERY good system people who are uninformed are the ones who complain about them. Does the primer get hard when you pump it.
dkosiewicz
Hi oldboat1,When the carb is upside down and the float is on top the float is exactly level with the carb's body.
Flyingscott I followed the instructions to the best of my ability last season and then took it to a local marina in Chicago and they went thru it and said they dont have the time to work on it but said they believe it is my carbs. The old VRO fuel pump only had 3 wires, which Evinrude doesnt make anymore. So when I installed the new VRO Fuel Pump it came with 4 wires. Te new one being a purple wire that is suppoed to be attached to the teminal block if there is a purple wire on it. And of course there wasnt. So it says to cut the main wiring connector removed the unused purple wire in the wiring harness and attached the new wire there. This is what the Marina did. I believe the purple wire that is cute that is going back into the connector is a dead end. block1.jpg Screenshot_20170701-000108.jpg The wires by my thumb lead back to the front of the boat and key.
dkosiewicz
And yes the primer blub gets hard and stays hard. I replaced all the gas lines as well as the primer blub and the gas line from the gas tank to the motor.
Joe Reeves
The 3 wire VRO's were superseded to the 4 wire around 1986/87. I'm surprised yours lasted as long as it did. Your explanation of the problem indicates that you're overlooking something pertaining to the carburetors.
(Fuel Primer Solenoid Function)
(J. Reeves)
The RED lever...... The normal operating/running position is to have that red lever positioned over top of the solenoid and aimed at the other end of the solenoid, gently turned to its stop. This is the normal/automatic mode position. Pushing the key in opens the valve within the solenoid allowing fuel to pa$$ thru it in order to prime and start the engine. Looking upon this solenoid as a electric choke results in a better understanding of it.
Having that red lever turned in the opposite direction, facing away from the solenoid, allows fuel to flow thru it to the crankcase area. One would only turn the red lever to this position in a case where the battery might go dead and the engine had to be started via the rope pull method. Look upon putting the red lever in this position as moving a choke lever on a choke equipped engine to the full closed position. Either one would supply fuel to the crankcase/engine for starting purposes BUT if left in that position while running would flood the engine.
The later model primer solenoids are equipped with a schrader valve, used for attaching a pressurized can of fogging oil etc, available at your local dealership with complete instructions.
Pumping the fuel primer bulb up hard fills the carburetor float chambers of course, but that process also applies fuel pressure to the primer solenoid.
The two small hoses leading from the primer solenoid branch off via tees to each fuel manifold section that would feed fuel to the individual cylinders.
Pushing the key in activates the primer solenoid to allow fuel to flow thru it to the intake manifold pa$$ageways. Cranking the engine over causes the fuel pump to engage which in turn sends fuel pulses to the primer solenoid via the 3/8" fuel hose.
Some engines incorporates the "Fast Start" feature which automatically advances the spark electronically so no advance of the throttle is required for starting.
Engines that do not have the "Fast Start" feature will be required to have the throttle advanced slightly.
Starting procedure: pump fuel bulb up hard, crank engine and push the key in at the same time. When the engine fires/starts, release the key so that it falls back to the run position.
Bottom line..... Look upon the primer solenoid as an electric choke.
(Carburetor Float Setting)
(J. Reeves)
With the carburetor body held upside down, the float being viewed from the side, adjust the float so that the free end of the float (the end opposite the hinge pin) is ever so slightly higher (just ever so slightly off level) than the other end. And when viewed from the end, make sure it is not cocked.
No attempt here to insult your intelligence... just a reminder... Make sure the float is not upside down.
dkosiewicz
Thanks Joe Reeves,
I appreciate all your input. I will flip the red level back to over the solenoid. I had found out about pushing the key and it pumps fuel thru the solenoid lines. But in either position it does that. So I wasnt sure which way it should be facing. I will pull the carbs off and check the floats and make sure they are they way you say. I am a expert at pulling them off now! lol Does my hook-up of the new 4 wire look done correctly? the 3 wires were easy black grey and white I think. But the purple one was difficult. When I get a chance I will do the carbs and post pictures of the floats. Are you able to look at the wiring diagram I posted? This site wont let me post it as one. So I will post the web site and then what goes after the web site address.
http://www.marineengine.com/ newparts/part_details.php?pnum=OMC5007421
dkosiewicz
I think Figure #13 is the purple wire coming from the front of the boat and its wiring harness and #11 is the wire leading back to the VRO Fuel Pump? "A" is where the purple wire went into the the harness plug but on the opposite plug it is a blank spot, no connector.
flyingscott
Do you have an an electrical bar on the motor. There should be a purple wire there that you attach the vro wire to.
dkosiewicz
Hi flyingscott,
On page 1 of this feed shows my terminal block. No purple wire there.
dkosiewicz
Everything is hooked up correctly I think, cleaned and I believed wired correctly and still it just kicks over and runs for a few seconds. Could the key start have anything to do with it? Also, I am thinking of putting the old VRO Fuel Pump back on and seeing if it will run. And then taking it apart and using the diaphragms for the old pump.
