1986 Bayliner Capri Questions
bkr8882
Hello,
I want to do some adding on to my boat. Like a new bimini top or a trolling motor. To do this I would have to drill into the boat above the water line, even if I seal all the holes using a rubber gasket or sylcone. How would I find out what size my gas tank is. I need to put some fuel stabalizer in the gas and the mechanic recommened seafoam, but you have to put in 1oz for every gallon. So thats why I'm looking for that information.
Thanks
Brandon
redone4x4
Re: 1986 Bayliner Capri Questions
i drilled for my bimini and it worked out fine. For the fuel tank, there should be a plate on it saying when it was manufactured and what its capacity is. I believe mine is either 31 or 33 gal.
