1986 Bayliner Capri 2.3 SOHC Volvo Penta Need Help
Starkboard
I have two problems:
1. My I/O drive raises and lowers fine when the boat is not under power. When I attempt to trim it out under power, it will not raise. If I raise it at idle and then increase throttle, it drops. I can't force it down manually, though. Any suggestions?
2. While the boat was parked in my yard with the cover on, someone threw a large rock that smashed out the starboard front side window and damaged the frame. Any suggestion on where to find a replacement?
Thanks for any help.
