1986 90hp evin. lift cylinder drops overnight
longjohn
The motor slowly drops over a period of 5-8 hours. There are no leaks. visually everything looks perfect. the manual release screw is tight. any help would be great
ezeke
Re: 1986 90hp evin. lift cylinder drops overnight
edit
longjohn
no, i haven't checked the fluid level yet. i would have thought if the fluid level was low i would have noises or problems in the most upright positioning. but i can easily check it. you feel it could cause the sag problem???
ezeke
edit
longjohn
the fluid level was perfect!! now what? thanks for your help!
