jrs_diesel
Thread starter- Joined
- Mar 3, 2010
- 552
I have a 1986 9.9 that I just got running again (I just bought the engine this past winter, good deal). The carb has the metal float bowl that had water in it so it had rusted up and clogged nearly everything. A carb kit, a thorough cleaning, new fuel lines, and she's running fairly well.
The issue that I'm having is that when I turn the throttle all the way to idle position, the engine dies. I can get the motor to idle if I set the throttle higher, and it idles like any motor would. How can I set it so that when I twist the throttle all the way to idle, that the engine will actually idle there? Seems like something is a little off, and I can't put my finger on it.
This motor is a little unique in that it was the first year that OMC installed the cable throttle in the tiller handle instead of the old gear/shaft setup.
