1986 85hp Force outboard Fuel problems please help
Tony Moye
So I have a 1986 85hp force outboard that doesn't seem to be getting fuel. When I get it started in the water the only way to keep it running is to keep pushing the choke. I have cleaned the carbs and replaced gaskets in the bowl and the intake, all cylinders have 120 compression. I looked at the diaphragm and it looks ok no holes or wear and the other gaskets in the fuel pump look perfect as well. It didn't have this problem until I broke down the carbs which the top one was missing the nozzle spring the middle one had a hole in the float but I repaired and replaced those issues the only thing that Im not sure about is the top carb was stripped out where the bowl screw goes into the top of the carburetor so I had to use a longer bolt to get good threads so Im concerned it may be blocking that bottom jet in the top carb a bit don't know if that could create this issue with no fuel getting in or not. Someone out there give me some direction where to go please i have also replaced the spark plugs and rebuilt the starter and changed out the water pump.....help:)
