alright guys, this is m first boat, so i will try my best. there was no water being pumped into the block, so i got a water pump rebuild kit. when i put it together there was an oring that from the other videos i watched went on the top of the driveshaft but its too big for it to fit there. Does it go between the impeller and the plate, or the impeller and the cup housing. while the oring was on top of the water pump, if i poured water into the water outlet tube, it would leak out of the top of the water pump around the driveshaft. is that supposed to happen. also, i had moved the oring to in between the impeller and the pump housing, and once i had the bolts tightened down, i couldnt turn the driveshaft with my hand, is that good or bad? I appreciate any help you guys can give me. thanks.
