- Mar 8, 2009
- 44,312
Your saying everything is good, yet it still dies after 10 minutes. The motor needs air, gas and spark to run, so at least one of these is not working.
In your post 10 you said
So you have proven your running out of gas. As Bondo and others stated stated
It will run fine from a 2 gallon gas but dies when reconnected to the tank. SO your issue is where the fuel line connects to the tank or parts of the tank. These parts consist of:
Anti-siphon valve
Tank pickup tube
Tank Vent line
You said the anti-siphon valve is good and so is the vent line. The only thing left is the pickup tube. The tube is where the gas line connects to the tank
Update, I had the same problem and ran the fuel line to a 2 gallon gas can I brought along. The boat ran like a champ. So what should my next step be?
The system consists of the tank, the vent, 'n line, the diptube, the A/S valve, 'n the fuel line to the motor,.....
It's restricted somewhere,....
Anti-siphon valve
Tank pickup tube
Tank Vent line
