I recently bought a '86 4 Winns 190 Horizon with an OMC Cobra and a 305 5.0 L. This is my first boat and I am having trouble with it starting. I've taken it out a couple of times and it started great most of the time , however occasionally it would do nothing when I turned the key. After a few tries or waiting a minute it would eventually start normally and I didn't think much of it. The other day I was going to take it out and I figured I try to start it before driving an hour and a half to the lake and it would did nothing. The gauges work when I turn the key on but no starter noise at all when turned to start. I noticed the starter looked very old so I figured I would replace it and problem would be solved. Wrong! I have since tested the ignition switch and it worked fine. I then tested the Slave solenoid and only got power on one of the terminals. I believe its the A terminal. I had someone turn the key for me as I tested the C and B terminals but got nothing. Grounds seem to be fine so I assume its the Neutral Safety Switch. How can I test the safety switch? Where is it located? How do I replace it? Or could it be something else?
Any help would be greatly appreciated. Pictures or helpful links would be great.
Thanks
Thanks
