1986 30 hp Johnson leaking oil around propeller?
dartman34
A grayish/green colored oil is leaking from around my propeller and I think it's coming from my lower unit. Can someone please help me solve and fix the oil leak? Isn't it true that if the oil is discolored, it could have water in it and shouldn't it be drained and changed out?
tashasdaddy
Re: 1986 30 hp Johnson leaking oil around propeller?
it sounds like you have a bad prop seal, which means having to reseal the lower unit. Yes, change the lube now, before any more damage is done. then tackle the problem. you can see diagram of lower unit here, http://shop2.evinrude.com/ext/index.aspx?s1=bf6ad09c53cead335fcfd8a6471c0f7f
if you do the work yourself, you need the johnson service manual. outboardbooks.com
