1986 25 HPJohnson wont run with the cover on
Sheyenne
This motor will run all day perfectly but when I put the cover on it will cut off after about a minute and won't start back unless you take the cover off. The cover is not touching any hoses or wires. I'm assuming it has something to do with the air mixture for this reason but can not find any adjustment. Any help would be greatly appreciated. Thank you
ondarvr
We have no clue as to what this motor is other than the year, but if the base gasket is leaking it can cause poor running with the cover on, but run well when you remove it.
Chinewalker
Okay, quick questions - is the cowling original to the motor? Any chance the lower cowling has been replaced at some point? At some point in the early 1990s, the air intake was moved from the belly pan/lower cowling to the rear of the motor hood. If some parts have been mixed and matched at some point in the last 30 years, it's possible you might have a no-vent cowling on a no-vent lower pan. If all is original, then I'd be looking for an exhaust leak.
F_R
Honorary Supreme Mariner
Are you running it in a barrel? If you are, there is the answer. It was made to run on a boat on the lake. Not barrel cruising.
