1986 25 HP Mercury 25M Has no spark
ducks136
My mercury does not have any spark on the plugs at all. I checked wires and unplugged the black with yellow stripe wire from the switchbox/powerpack and still no spark. How do I test the switch box with a cheapo meter from northern tool? before i spend money on a new box and it possibly not be the problem?
Laddies
Banned
Re: 1986 25 HP Mercury 25M Has no spark
Here's the test from CDI, you can't test the box but if everything else tests OK then it's the box.
ducks136
ok should i hook the box back up to the boat or will i be able to test those components without the box hooked up because i have already pulled it off. Also will i be fine just by checking the OEM resistance or do i need to check the DVA and also if i do I have no idea on what DVA is, I am no electrical engineer by any means. Thanks
Laddies
Banned
You don't have a DVA, with the wires disconnected use your ohm meter and the resistance readings
ducks136
ok i'll give it a shot after work tomorrow
ducks136
ok i put the meter on it tonight and everything read out fine. The only problem i thought i found was the first wire test where the ohms were to be 3250-3650 and i did not get a reading until i tried to start the motor. However, i was able to run the same test on a similar motor (89 mariner 15hp) and it was the same deal on the first wire test but everything else matched perfectly to mine with the ohm resistance tests. So I guess it would be safe to say its the switch box gone bad and i probably will order a new one. Am I right?
ducks136
Ok I recieved my new sierra 18-5777 switch box today and i am having trouble trying to identify which of the two black/ yellow stripe wires with the same bullet connections is the kill switch and also does the green wires with either the yellow or white stripe matter which spark plug do they go to?
ducks136
Nevermind I hooked it up anyway and played with it until i got it right. Motor runs perfect now. Thanks for you help!
