1986 20hp johnson seahorse gas blockage
GAZOO
Hi. I'm having a really hard time starting my 1986 20hp johnson outboard. Used to fire up after 2 to 5 pulls. I've noticed I had air in my gas line coming from my primer to the carb and that the primer was really hard to pull out. I removed the gas line and gave a shot of primer and the gas flows no problem. However when I reattach it to the carb and pull the primer again I see air form in the gas line and the primer is really hard to pull out. Almost seams like the gas does not want to go into the carb, any ideas
GAZOO
Anyone!?!?!? This motor has one of those injection primer that squirts a shot of gas directly into the carb
AlTn
ain't much help, but you can find diagrams of the primer at marine engine dot com if you want to disassemble it for cleaning and inspection
Vic.S
Or the BRP parts website . which can bb copied and pasted into posts as below!
It sounds as though something is blocked. If I understand you correctly it seems that the connection for hose #13 could well be blocked.
convert
GAZOO
Thanks guys. Hose # 19 at the carb. I just picked up a carb kit from my local johnson dealer. They had no openings for a mth so I'll be rebuilding it myself. I think something is just plugged up. Guess I'll find out tomorrow
