1986 150 merc oil injection?
duff
what does it take to disconnect the oil injection system on a 86 150hp merc? I am looking at a boat that the owner says runs but the injection system needs work. this is the xr2 black max if that matters....
any help would be great.
duff
Damdan
Re: 1986 150 merc oil injection?
Duff, lots have been said about this matter so you will find very useful information through the search fuction.
duff
yes i agree here is the problem, I am looking at this boat to buy I do not want to purchase this kit to remove it for good unless i buy the boat and try to run it with premix for good. so is there a way to disconnect the oil injection system and run on a premix tank of gas to test drive the boat and check how the motor runs. I know to check the compression, L/U lube, pee stream, hull, transom, deck/floor for soft spots. i am not sure how to disconnect the injection and run it with out where the current owner would be OK with. so after all my rambling i need to know is there a way to remove it for testing?
any other advice or input on buying a used boat would be apprciated.
duff
