1986 125HP Stalls when shifted in gear?
Larman
1986 125HP Stalls when shifted in gear, I have to quickly go from idol to forward in order not to stall. Any ideas on how to fix? Im nervous about adjusting the two carbs.
Frank Acampora
Re: 1986 125HP Stalls when shifted in gear?
Idle speed is too low. If this just started, it is probably fouled plugs. Cl;ean or replace them first, then, if that doesn't work, look for other reasons for the low idle.
hondakillrsx
I just had this problem on my 92' force 50. All it took for me was adjusting the mixture screw quarter turn counterclockwise.
