1985 XP150
Melvin Hatcher
I plan to overhaul the carburetors on my 1985 XP150 this winter.<br />My question is; are all three carburetors the same on this engine, or is the center carb the primary and the top and bottom, secondary carbs? :confused:
JB
Re: 1985 XP150
All pretty much the same, DoferGofer.<br /><br />BUT: Put each one back where it was, and please use a manual.
Melvin Hatcher
Re: 1985 XP150
Thanks JB,<br /><br />I have a factory manual. However, is there anything I should pay particular attention too while rebuilding the carbs, other than just following the manual? Any trade secrets? ;)
OBJ
Re: 1985 XP150
Dofer....just make sure you hose out the passages with carb cleaner followed up by compressed air. The manual will guide you through the process.<br /><br />Keep in touch.
