1985 sears gamefisher 7.5
searsgamefisher
Hi I am new, I have a 1985 sears 5hp outboard model 217-586613 and it starts right up runs for a second and dies(will not idle).I rebuilt the carb and I think I did it right.The motor reves up really high during that second and it also makes a fluttery high pitched sound right before it dies.Could this issue be behond the carb?....thanks Robert
DCT
Re: 1985 sears gamefisher 7.5
Sounds like fuel shortage problem. have you checked fuel flow to carb from tank? Will it run with the choke on ? Have you tried spraying carb cleaner directly in carb, if it will run on carb cleaner you have a carb problem or lack of fuel problem.
