1985 OMC power tilt/trim fades
bruce_franke
I recently acquired a used 1985 power tilt/trim unit from a 2 cylinder 50 hp Johnson. This model unit has a bracket that bolts underneath the outboard's transom bracket that supports one external cylinder on each side of the outboard that handles both tilt and trim. The pump and motor is attached to the right side of the right cylinder, looking at the back of the boat. <br /><br />It works great except that it fades slowly when tilted up. It doesn't leak and the fluid level is full. I would like to fix it myself, but am unsure how to proceed. <br /><br />I am told that the problem could be one of several check valves in the system. The factory OMC parts catalog lists only one check valve assembly and a check valve repair kit with the same part no. 173569, but doesn't show it in the diagram. I don't know where they are located or what they look like. If I take it apart, how do you identify a bad one? Are there other components that I should be looking at?<br /><br />I have searched the forum, but found nothing on this model.<br /><br />Thank you for sharing your expertise with me on this.
