1985 mercruiser 120/140 will go forward. will not go reverse
13adluck
Boat will only go forward. will not go reverse. when you put it in forward you hear it lock in a prop spins. when you try reverse it only throttle up will not lock into reverse and prop will not spin. Anyone know what might cause this?
Bt Doctur
Re: 1985 mercruiser 120/140 will go forward. will not go reverse
lower shift cable/shift assembly/poor adjustment.Pull the drive to isolate the problem.
jerryjerry05
Shift cable is probably bad.J
Here is a diagram to help adjust the lower shift cable if that is just out of adjustment. I don't believe that they loose adjustment on their own though unless someone messed with it. Checking it for adjustment is an easy thing to check off before you get deeper into it.
Click the image to enlarge.
cedarjunki
I don't believe that they loose adjustment on their own though unless someone messed with it.QUOTE]
they do stretch though.
also the actuator on the end in the outdrive has broken on me before too.
