1985 Merc 115 dies at full throtle
quebec#1
The engine runs fantastic at high speeds and low and idles and starts up very well.
My only problem is if im cruising around lets say around 5 to 10 mph and hit the throtle it will at times (not always) just bog down to a near idle. If im gradual on the throtle and then pin it theirs no problem.
Laddies
Banned
Re: 1985 Merc 115 dies at full throtle
You have a lean condition either the idle jet settings or the backdrag jets are causing it. I would remove the backdrag jets first and try the engine if that don't help reinstall them and readjust the idle mixture.
quebec#1
backdrag jets ? Where are they ?
quebec#1
Still would like to know where the backdrag jets are located ! Any pics ?
Laddies
Banned
The backdrag jets are in the float bowl vents at mid range they cause a vacume in the float bowl dropping the fuel level and leaning the engines mid range helping the blubber but at WOT it has no effect
arsenalpsu
to disable that vent just put a BB in part #11 (vent tube) on that marine.com picture. You may also need to adjust your idle screws, search for the "Link & sync" that clams made. IF you're sinked correctly you might need to move each idle screw out 1/4 turn.
