Re: 1985 Mariner 150 Carb leak
With a little work, I managed to pull the bowl off the carb without having to remove the carb from the engine....good thing it was the bottom carb. Once in side I pulled the float, needle valve and needle valve seat. AHHHH-HAAAA,
about a 1/4" piece of gasket material sitting right under that seat. cleaned it all out, and put it back together. Only had to replace one small casket under the needle valve seat(tore when I went to put the seat back in) Got it all back to gether and the old motor cranked right up and best of all no leaks anywere.
Good work. Are you a surgeon or somethin'?
My father in law had a car that was starving intermittently, usually in the middle of an intersection. He'd had it to the dealer about 5 times with no relief, just bills. One day it was starving when he pulled into my yard. I checked it out and said "It needs a carb kit." He said, "They just put one in last week."
I had to agree to do the labor for free, eat the parts, eat crow, and take him out to lunch if I couldn't find the problem. When I tore down the carb under his watchfull eye, and got to removing the main jet, he said, "You don't need to do that. The other mechanic didn't." Well, guess what? Under that jet was a little curl of brass that had probably been there since the factory.
Morale of the story. As you found out, go with your own diagnosis.
My 02
John
