1985 johnson150 hp j150txcos idle trouble
liorlilah
Hello everyone.
i have an engine for about 2 month we replace all the fuel line and rebuild the carbs as the boat had set for 3 years.
when we start the engine it runs good at around 1100rpm but after a minute it will sometime jump by itself to 2500-3000 rpm. does anyone have any ideas on what can make the rpm jump like that.
thank you.
emdsapmgr
Re: 1985 johnson150 hp j150txcos idle trouble
Check the spark on each plugwire. All the plugs may not be firing. It's possible that the engine is only running on 3, 4 or 5 cyls at 1100 rpms. When all 6 cylinders kick in, it will go up to 2500. You can do a cyl drop test, or check each with an inductive timing light.
monnewbie3
Are you running 1100 Rpm on muffs or in water? Does the engine smoke and sputter?
I would check your timing to start and see what happens
liorlilah
thank you, i will check mi timing today and let you know, i am running the engine on muffs. the engine does sputter just at the exact moment when it start to go up in rpm.
thank you monnewbie3 and emdsapmgr.
liorlilah
Ok. i check the spark on the all the cylenders and on starbord ther is no spark on all 3.
what should i check i switch the power packs around and it did not change anything.
could it come from the timer base? or stator,regulator.
let me know what you hing
Thanks you
emdsapmgr
The power pack swap is a good test. Two other potential sources of problem: the stator or the timer base. The factory service manual tells you how to qualify them. You may find also relevant troubleshooting information at this website: cdielectronics.com
