fishinfreak
Thread starter- Joined
- Sep 10, 2003
- 4
Hello Everyone! Thanks in advance for the help. <br /><br />I have read similar postings to my problem, but I am not sure of the alarm condition I am getting due to the fact there seems to be 2 issues. <br /><br />I have the constant alarm problem, which I believe is the high temp alarm. It is intermittant, but sometimes comes on immediately even before the engine is started. Here is what I have noticed:<br /><br />Good Oil pump pressure<br />Water flow out from the pee hole seems to be fine<br />Happens even when 1st starting (sometimes)<br />Good high speed performance<br />Doesn't stall, but idles a bit rough after alarm comes on during low speeds<br /><br />Here is the second part:<br />Engine will not start unless I use the Emergency start procedure (even with a tight gas primer). I have to flip the switch, pump the ball once, return the switch and start it. <br /><br />I am not totally sure if the alarm is overheat or fuel starvation. It seems Johnson changed them over the years.<br /><br />Any help or ideas would be appreciated! Thank You!
