1985 Johnson Seahorse 55 shuts off
SBrink
Hello.
Last year my seahorse 55 started acting up. Sounded like one piston didnt ignite properly and it would rev(?) very unevenly, and eventually just die by itself after about 30sec. This past winter I've changed the coils and water pump which had 2 tears in the membrane, which I guess could maybe mean it leaked air so maybe why it died. Now when I started it after 4-5 month of winter it started off first try and ran really well for a while. But soon it started making these strange noises like one circle of the crank shaft would be faster than the ones before, and died again after about a minute. Any ideas what I can check for? The console also gave my hand a shock today so could be a bad ground?
Thanks for any help! -Sid
Bosunsmate
Ive that motor. Run it again unil warm and then try pulling one of the coils off with insulated pliers and grounding it and seeing if you can track down which cylinder that misfiring is coming from.
You should also run it at night and see f you can find a short happening.
