1985 Johnson intermittent spark both plugs
PeteSv
I have a 1985 Johnson 25hp outboard model J25TELCOS that was running great then sputtered and died. I rebuilt the carb and got fresh gas since I saw spark but didn't notice it was intermittent before i rebuilt the carb . Checked compression and looks good on both cylinders, fuel pump looks OK since gas spurts out disconnected gas line when turning over. It will fire but won't stay running. I replaced both spark plugs but only get occasional spark on both plugs, won't even stay running with starting fluid. The motor has a single external power pack mounted on the engine. I suspect either stator or power pack. Can someone please tell me the steps to diagnose, I'd rather not keep throwing parts at it? I searched the forums but didn't find anything that fit my setup.
juno pierrat
you will want to get a manual, if your going to trouble shoot yourself, also a dva volt meter or dva adapter to take the proper readings. basically these 80's motors have four things to test, P/P, charge coil, trigger sensor, and coil. many steps to testing all four. the stator, and rectifier charge the battery. i'm betting its the charge coil or P/P. Iboats has manuals and maybe online. watch the starter fluid, been told it can wash lub from bearing and stuff, more damage then help.better to use pre-mix gas to spray in carbs.
PeteSv
Thanks for the replies, this might be a little over my head. I'd rather take it to a shop but they're all booked three weeks out
PeteSv
Thanks for the pointer Juno! Your talk of needing a DVA volt meter kind of scared me. I have a mulitmeter and I've seen writeups on how to build my own DVA meter, I may try that. Is the trigger sensor and charge coil under the flywheel by the stator (haven't checked the manual yet)? There are two coils with spark plug leads, is that what you meant? If so they both show intermittent spark so i wouldn't think both went bad at the same time. Thanks for your patience with a newbie.
juno pierrat
yep you got it, probably not spark plug coils unless cracked, i've had charge coil go bad twice, yep can build a DVA or on line under $30
PeteSv
It was the power pack. Unfortunately radio shack went out of business so that put a cramp on building a DVA adapter. Rather than spend $50 for one online I broke down and bought a new power pack from the local marine shop for $100. Got lucky, runs like a top now. Thanks again to those that replied!
