1985 Johnson 90hp V4 Cylinder Heads will johnson 115 do please help
badenemy
Hello People Heres My Problem I Have A Johnson 90hp V4 1985 But The Cylinder Heads are Damaged Due To Pistons Ive Replaced Pistons But Cant Get Hold Of New Cylinder Heads But I Have Cylinder Heads Of A Johnson 115hp Will these Do As The Bolts Line Up But The Grooves Are A Bit Different Any Help Would Be Greatfull.
F_R
Honorary Supreme Mariner
Re: 1985 Johnson 90hp V4 Cylinder Heads will johnson 115 do please help
I haven't checked, but isn't the 115 a larger bore? Won't work if it is.
Dhadley
Both those motors were 3.500" (std) bore. Yes, the heads will work just fine.
