Re: 1985 Johnson 90 vro......too smoke
Delchilu,
Can you perform a compression test and post the results? Can you provide some information regarding the history of the engine? When was the last time the carbs were cleaned (and rebuilt, including float height), when was the last time the engine was decarboned. Do you ever run the engine at full throttle? Does the engine smoke just when it is idling or even under 1/2 or full throttle conditions?
And just on the chance... is your VRO system hooked up and working, i.e. do you put your oil in the gas, or do you put your oil in the small oil tank and let the VRO mix it with the fuel.
warmly,
fp
