1985 Johnson 9.9 flooding badly
mustard73
I have a 1985 Johnson 9.9 that is giving me some grief. I had it out on the weekend and the motor ran pretty good all day, started first pull, idled down and trolled nicely, etc. Towards the end of the day, I opened it up to WOT to cruise to a different part of the lake and when I got there I slowed down to find a place to anchor then the motor died and would not start again.
I don't have the top portion of the air silencer installed and noticed that the bottom portion was totally full of fuel. I removed it and emptied it out then the motor fired but would barely run and only if I gave it a lot of throttle (flooded I'm sure). Once it seemed to clean out a bit, I reinstalled the bottom portion of the air silencer and started the engine again but it started filling up with gas very quickly. I managed to limp it off the lake at WOT without the air silencer to catch the excess fuel but it wouldn't reach rpm and was running very rough.
I will remove the carb and inspect but I had just had it apart before the trip. I assume that the float is not sticking open since the ball gets firm.
Also, I rebuilt the fuel pump last year so I doubt the diaphragm has a hole in it.
Is there any other way this thing can overfuel so badly?
nwcove
Re: 1985 Johnson 9.9 flooding badly
if you just had the carb apart before the trip...theres where to start looking. ( why did you take it apart?) you could have a bad/leaky float, check to make sure its not full of fuel.
mustard73
Just had it apart to make sure it was clean after sitting all winter. I replaced the old cork float with a new plastic one while I was in there because I had one laying around.
I'll take the carb apart again to make sure everything is operating properly though, as you recommended.
nwcove
cork float? in a 1985 motor? if you still have the old float compare the two.....not all floats are the same, and youd be a bit on the lucky side to have the right one " laying around".
mustard73
I pulled the carb apart tonight and everything seems to be in order.
The motor has spark.
Next thing I will check is compression.
Has anyone had this same problem before? It seems like fuel is blowing back. Reeds maybe?
