1985 Johnson 9.9 Dead End Please help!!
lsherman
Hello all,
I picked up a cheap 1985 Johnson 9.9 locally from a seller that stated it ran "great" before storing it 2 years ago. Yeah right...
The motor appears to be in good shape for its age, before firing the motor up I replaced the impeller and water pump housing. The next thing I did was soak the carb in seafoam and blow it out, assembling it with a rebuild kit. The bottom of the metal float bowl was full of varnished sludge that left some discoloration in the bottom of the bowl. The throttle cam plate was frozen but after working it for a few hours it rotates easily. I then proceeded to change the lower unit gear oil which had no metal shavings. I bypassed the motor fuel lines and hooked a funnel with a fuel line to the carburetor and attempted to start it. The motor didn't even try to fire. I took some pre mix in a spray bottle and sprayed it in the cylinders and the air intake it went around a few times but that's all. I then checked compression and got 90 psi in both cylinders after pulling a few times. I checked the spark plugs that were just bought with a in line checker, the bottom plug had no spark but the top plug looked good. After diagnosing the problem I replaced the lower ignition coil and now both plugs are looking good. I then sprayed premix/seafoam mixture in the cylinders and air intake and it fired up for about 5 or 6 seconds then died. I had the throttle at 3/4 and choke on. I pulled again it fired and immediately died, attempts to start afterward were useless. I pulled the plugs and they look clean. Every time I spray my mixture in the cylinders it fires up, without it I have no luck. I removed the flywheel and the key looks good. I did notice some black goo on the ignition plate that is dried up, it looks like the coil is leaking. I haven't tested the stator or charging coil assuming they were good from the spark plug test. I did notice the crankshaft seal looks dirty but I'm not sure if its defective. I'm at a dead end and have no idea where to go next!!! I would be grateful of any feedback, thanks so much!
oldboat1
You depend heavily on Seafoam, but according to their ads it's just a petroleum product and won't do any harm. Thing is, it might not do what you want in order to clean the carb. I use lacquer thinner to remove varnished fuel -- disassemble and soak, then poke at all openings with thin wire. Finish by blowing out with carb cleaner, reaching into all orifices with the plastic nozzle. Disassembly includes opening up the top of the carb by removing the domed fitting. I leave linkages in place and soak both top and bottom halves of the carb (metal parts only). As you carb was badly varnished up, you might want clean it again.
lsherman
Ok ill take it off again, soak it in lacquer thinner and clean it. I've taken it off a few times to clean and every time I do the bowl is full of fuel. Would pressurizing the system using the fuel lines on the engine some how force the blockage if there is one in the carb? I feel as if the gravity fed system I have going now may be a problem too.
tpenfield
Like the others have said, I think you have proven that fuel delivery is the problem so go back through it including the fuel line, etc. Soaking does not free up clogged jets . . . you often have to use thin wire, etc. to clean them out.
lsherman
I really appreciate the feedback, I'll clean the carb again and report back in the next few days.
