1985 johnson 50 hp throttle cable problem or linkage?
erie sea nymph
Hello new guy here. I purchased a 1985 ss175 sea nymph with a 1985 50 hp johnson . The problem im having is when in netural while lifting idle lever all the way up motor does not rev up . And when in the water has very little power in reverse. But in foward i have alot of power. im assuming foward is ok. But i dont know if this is a throttle cable issue or linkage issue. Any help in figuring this out wojld be greatly appreciated.
fireman57
Sounds like you have a powerpilot control. Big white one with single handle. The lever is probably not hooked up in the box. These things are tricky and I hate taking them apart. Take your time and be careful. As for reverse you shouldn't be able to go real fast in reverse. The throttle is set to not rev real high in reverse for safety reasons.
1983 ercoa 21'
I would pull the hood and have someone move the lever while watching at the motor to see if anything moves.
if the controls match the year them controls are pretty simple and shouldn't be the bigger older style that wasn't a simple.
this could be a simple adjustment seeing how the boat is new to you ,your not sure who has done what,like change a cable and didn't adjust it correctly.
