1985 Johnson 4HP prop spins upon load
fullerroad
hello I have a 1985 Johnson 4HP model J4BRHcob which runs well but at 1/2 throttle the prop spins freely up to 1/2 throttle it works ok but I can't go pass 1/2 throttle as the prop spins and the engine revs up. is it a bushing that needs to be replaced or the spring inside the lower unit is worn or weak?
thank you
QBhoy
More likely a shear pin broken up, on an engine like that. At a guess.
