Going by the model number it looks like I have a 1985 Johnson 35. Runs great at idle but terrible when you start to give it throttle. I’m thinking the high speed jet is dirty. When I look at parts breakdowns the carb does not look exactly the same. I’m pretty sure it it OEM. My carb has a brass vertical tube that runs ut the middle. It has holes drilled into the sides of the tube. Ther is also a smaller tube inside the larger. The parts breakdowns don’t show this. Anyone have any ideas.
