1985 Johnson 120
Florian10
Hello everyone,
I'm having a hard time with my engine. I removed the lower unit for a new water pump and since i put it back together the reverse gear does not engage properly. Can someone please verify the correct height of the shift rod needed!!
I have searched everywhere with no luck.
Info:
1985 Johnson 120 V4 - I believe it has the V6 gear case since the spline is 15 tooth, not sure if this makes a difference.
J120TLCOS
Any help will be greatly appreciated!!!!
Cheers
