1985 Johnson 115 V4 Bogging at 5000 rpms... Need help diagnosing
CameronProcraft
So I have a new to me 1984 Procraft 1650v. It has a 1985 Johnson 115 V4. The motor cranks good. It idles good. Here is what I have done to the motor and then I will explain the issue. First thing I did when I got it was drain the gas tank. I replaced the spark plugs, rebuilt/cleaned the carbs. put an inline fuel filter after the bulb. Took it to the lake and again it cranked good, idled good, I went full throttle and it ran great, sounded great, planed out perfect. Here is where the issues began. At 5000 RPMS the motor bogged down, went to about 3800, then started rise up again, when it hit 5k it bogged again. It would just rise and fall over and over again.Could this be a power pack? stator?
Honorary Supreme Mariner
Start with a compression test.------Then do a " maximum output " test on ignition system.--------Does spark jump a gap of 7/16" on all 4 leads.------Then again it could be as simple as a plug lead shorting to the cowling , so test run with the cowling off the motor.
CameronProcraft
Compression test was done when I got the boat. All tested good at 120. I haven't tested with the cowling off. I can do that. Why would a lead shorting not happen at lower RPMS? Thanks so much for your help!
Sorry, I am not standing beside your boat.-------Information is needed and trouble shooting has to be done.
CameronProcraft
Happy to trouble shoot.. what would you need? what would I do first? Newbie here :)
would you start with the powerpack? stator? Thanks for responding so quick racerone!
I would test the spark output.-----If that is good then test run with a " known to be good tank and hose "-----During the test run have an assistant ready to operate the manual pump if motor falters.
CameronProcraft
I I thought that could be the issue.. I will take it off and run it. It will be later in the week.
Bosunsmate
You can also pump the fuel bulb when you a out there, that acts as a manual fuel pump, that way you can check if your fuel pump is failing
glust
Not sure if this is your issue but I had a similar problem. After running hard the motor would sputter and then recover. The fuel bulb was collapsed. Seems the tank cap was not venting. The check valve was vapor locking the fuel line. The bulb collapsed. I opened the fuel cap a bit and the problem went away. Clened out the cap real good to restore venting.
CameronProcraft
ok, so I took the Procraft to Guntersville this weekend. What a great lake! Anyway as usually it cranked and ran well until it hit 5k. While I was running I did the bulb test and as suspected the engine came alive. It revved up an acted like it should. Today I ordered a new fuel pump as suggested. Anything else I should do or do you guys think this will fix it?
Bosunsmate
That should fix it. You should also as an aside replace the water impellor and the gearcase oil and also check the telltale outlet wraps up over the motor which helps minimise the likelihood of airbubble pockets forming in the head
CameronProcraft
**Update** I got the fuel pump in and installed it today. I am not at the lake so I am cranking it in the yard on ears. This motor fired up the first time. It has never done that!! it stalled just because of being cold natured. I hit it again and it cranked and just purrrred. It has never run this well. I am taking to the lake tomorrow. I will update on how it runs above 5k. Thanks for all the help.
Bosunsmate
Remember that to activate choke you push in the key, a lot of people dont know that so i ve said this just in case.
When mine starts up cold i just bump the key in every so often as its about to stall until shes warm
CameronProcraft
**UPDATE** I replaced the fuel pump and it ran awesome. Cranked perfect all day and ran at 5600 RPMS and 42 MPH all day. Very happy with the motor. Thanks for all the help!
