1985 Johnson 115 Lower Unit Interchange
deadnwater
I need a replacement lower unit for my 1985 115 Johnson, 20" shaft. What years and models are interchangeable with my motor ?
Dhadley
Re: 1985 Johnson 115 Lower Unit Interchange
Welcome to the board!<br /><br />Any 20" V4 from 1979. Any 20" V6 from 1979 (requires a prop change -- will have a higher gear ratio also). Any 20" V8 gearcase (same deal).<br /><br />I would strongly suggest to stick with the V4 gearcase.<br /><br />Why cant your current unit be rebuilt?
wilde1j
I don't think you have an 1985 115. 120 was the size Johnson had that year ... the first year for the loop charged motor in that size range and completely different than the 115 crossflow motors.
Dhadley
WildeOne, youre right about that being the first year for the 120-140 looper. But there was a 115 cf that year. That was the first year the 140 cf was "rated" at the propshaft rather than the crank and was dubbed the 115. OMC showed them at the old Chicago show that year as "the worlds most powerful 115". That stirred the pot!!<br /><br />The 1985 V4 20" looper gearcase can still be used but it'll need the larger V6 prop and has that odd gear ratio.
deadnwater
I will double check the year. The lower unit was rebuilt last year, but has failed again - all gears and bearings are trashed. Will any V4 gearcase fit from 1979 to present ? Are the gear ratios the same in all V4s ? Marineparts.com talks about Skinny and Wide housing V4s - how can I tell what I have ?
Dhadley
Most likely what they mean is the V4 style and the V6 style (size). Both will fit your V4. The V4 style generally uses a prop in the 13 - 13 1/4" diameter range. The V6 style use a prop in the 14 1/4" diameter range.<br /><br />Dont forget to check out the gearcases here at iboats too.<br /><br />Post your model number!!!
